Help with Jeopardy circuit ... will this work
Discussion in 'Homework Help' started by gte, Dec 14, 2010.
  1. gte
    Thread Starter Active Member
    Sep 18, 2009
    347
    Hi, my assignment is as follows
    "Design a buzzer to be used on a game show. 3 contestants each have a button to depress if they would like the opportunity to answer a question.
    Features
    - Once button is depressed, all other buttons must be ignored (dismantled).
    - An LED is illuminated to indicate that a button was depressed and the LED shall stay lit for 5 seconds.
    - System may be reset by the operator or automatically.
    * Bonus - if contestant answers incorrectly, their button shall be blocked until reset"
    Here is my circuit, please tell me if you think it will work. Thanks for reading.
  2. Kermit2
    Feb 5, 2010
    3,854
    968
    What function does the transistor serve?
    What will debounce the switches?
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    I don't think switch bounce would play into it, since the first pulse in a "bounce string" would be all that is needed to trigger. Debouncing could be added for fussy gates or extra credit, though.
    I am unsure of the bonus question of "leave button disabled for rest of round". What determines "rest of round"? I've not watched the show.
    gte likes this.
  4. gte
    Sep 18, 2009
    347
    The master reset enables all switches for the following question and the transistor drains the cap completely disabling that contestants counter until the next question/time the master reset switch is pressed enabling their button for the up and coming question.
    What about the rest of it?
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    Check this guy's circuit. It's mostly what you want, except from the disable functionality.
    http://forum.allaboutcircuits.com/showthread.php?t=46830
    You might want to to away with the transistors, as they will ruin the reliability and energy consuption of your circuit. Try to play a bit with the disable fucntion of the 7447 or the FF IC.
    gte likes this.
