Help with Infrared Transmit Circuit using IC 555
Discussion in 'The Projects Forum' started by dknovo, Dec 22, 2014.
  1. dknovo
    Sep 8, 2014
    8
    Hello everyone, I am designing an infrared transmitted circuit using ic 555 and i wonder that
    IC 555 will transmit an interrupted pulse to the Received circuit ( I mean the IC blinks leds )
    so, what is different between using IC 555 in the circuit and without using IC555 in the circuit.
    Why don't we transmit Infrared light directly to the Received circuit without using IC555 ?
  2. ericgibbs
    Jan 29, 2010
    2,590
    390
    hi,
    By switching the IR emitter On/Off with a 555, the IR beam is effectively AC, so the receiver can be AC coupled and any ambient light will not be amplified by the receiver amp.
    E
