Help with ignition spark engine waveform TINA
Discussion in 'The Projects Forum' started by shinsa101, Jun 25, 2011.
  1. shinsa101
    May 24, 2011
    Hi I am currently having trouble constructing a realistic waveform of spark ignition engine using TINA-TI. I am trying to combine 2 signal generators to create something realistic but I am new to TINA so I am stuck. Any suggestions?
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    It's been a while since I've used the Tina TI, so I don't remember the components that that version supplies. I created this is Tina Classic with very arbitrary values. It basically models (sort of) the old breaker points ignition system. SW1 is a progammable timed switch that simulates points.
    BTW, LT Spice is free so you may want to download it. I use both but mainly Tina.
  3. ANTALIFE
    Jul 14, 2011
    Sure is ENEL200 in here
