Help with identifying these SMD components
Discussion in 'General Electronics Chat' started by Geordi59, Oct 14, 2014.
  1. Geordi59
    Oct 14, 2014
    Hello all,
    I am new to surface mount components, thus I am requesting assistance in identifying the (8) eight components above.
    For example, I would assume that the three-lead components: ROY & CZ4-A7 would be transistors, but I have come to find that in the world of SMD, this is not always the case.
    Thanks in advance.
    Geordi
  2. Geordi59
    Oct 14, 2014
    UPDATE:
    I am learning everyday, thus I believe that both components ROY and CZ4-A7 are SOT-23
    ROY dimensions are 3.0mm x 1.3mm
    CZ4-A7 dimensions are 2.9mm x 1.3mm
  3. JWHassler
    Member
    Sep 25, 2013
    204
    34
    "R0Y" (Are-Zero-Wye) is an AD1580ARTZ voltage reference
    "CZ4" might be a BFS19R transistor.
    Go look for yourself: http://www.dl7avf.info/charts/smdcode/index.html#TOC
    You're gonna have to measure those passives, though.
    If this is real important to you, I'd spend hours/days tracking down a schemetic
  4. Geordi59
    Oct 14, 2014
    Thank you JW
