Help with identifying smd part - G4EE 6pin package
Discussion in 'General Electronics Chat' started by Mad Professor, Oct 2, 2014.
  1. Mad Professor
    Thread Starter Active Member
    Apr 15, 2009
    133
    Good day all.
    I am looking for some help with identifying an smd part.
    The smd part is in a 6pin package and has the part number G4EE on it.
    This circuit board is the BMS board from an e-bike, the problem is that one of the cells under/over voltage protection does not seem to be working, and I feel that this part might be the issue so I am trying to find out what it is, and if possible to find a datasheet and or a suitable replacement part.
    Thanks for your time.
    Best Regards.
  2. RichardO
    May 4, 2013
    1,342
    431
    First of all, what is the "BMS board"?
    As you may already know, a simple Google does not work... I could not find the G4EE code in on-line indexes.
    You may have to reverse engineer the circuit around the part to get a feel for what it is. For example, it could be a transistor, voltage comparator or an IC specially designed for this battery charging/sensing use. It is hard to tell looking at your (excellent) photo.
  3. ISB123
    May 21, 2014
    1,240
    531
    I think that it is a microcontroller probably something like tinyAVR.
