Help with identifying a transistor
Discussion in 'General Electronics Chat' started by nerdegutta, Mar 22, 2014.
  1. nerdegutta
    Thread Starter Moderator
    Dec 15, 2009
    2,566
    806
    Hi.
    Could someone verify that this is a 2N3904 transistor. I do not remember, nor did I label the envelope it's in.
    ... and the guys at Google are not helping ... :)
  2. Dodgydave
    Jun 22, 2012
    5,155
    772
  3. t06afre
    May 11, 2009
    5,939
    1,222
    Maybe Google did not help you, but by using the Altavista search engine I came up with this:p http://www.s-manuals.com/smd/r1 So I think you are on the correct track. SMD markings are an odd field. But serching on the 3 first letters only and function like "R1A transistor", or "R1A NPN" often bring good results
  4. nerdegutta
    Dec 15, 2009
    2,566
    806
    I assume it's an 2n3904. Yes, I know:"Assumtions is the mother of all f'ups"
    I'm living on the edge now, taking big risks... :eek:
    Thanks for the replies!
  5. t06afre
    May 11, 2009
    5,939
    1,222
    If you do not live on edge you are taking up to much space:D
  6. nerdegutta
    Dec 15, 2009
    2,566
    806
    I'm not taking up nearly as much as you, Mister!!:D
  7. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    There are various SMD lookups online, some are PDF, you can convert the html ones into PDF with the CutePDF application.
    You have to watch out as some SMD markings are duplicated for 2 or more devices - usually identifying the package style narrows it down.
  8. Brevor
    Apr 9, 2011
    282
    56
    I believe 1A is the marking for a 2N3904, The R may be the manufacturer possibly Rohm I know they make a 2N3904.
  9. ian field
    Oct 27, 2012
    4,447
    791
    An "R" suffix can sometimes denote an alternative pin layout - it wasn't uncommon on stud rectifiers.
  10. nerdegutta
    Dec 15, 2009
    2,566
    806
    The attached datasheet says that
    So I am pretty sure it's an 3904 npn transistor.
