Help with high-voltage insulators.
Discussion in 'The Projects Forum' started by rc10mike, Sep 21, 2014.
  1. rc10mike
    Jul 17, 2014
    7
    First a little background on the project:
    I recently got a brand new Sears bug zapper. Its a model from the late 70s or early 80s. It worked great for a few weeks then one night it wasnt zapping. Upon inspection of the unit after removing power, I found one of the 4 plastic grid insulators was burned. These little plastic insulators are what hold the entire HV grid in place. Unfortunately, Sears no longer sells the insulators as shown here # 33
    http://www.searspartsdirect.com/par...7/1500155/00023776/00001?blt=06&prst=&shdMod=
    So, my new zapper is dead because of one simple piece of plastic. I want to make some new ones. Would HDPE work in this application?
  2. #12
    Nov 30, 2010
    16,665
    7,314
    Probably. What do you have to lose? 15 minutes of carving a spacer?
    Most plastics will work. Any spacer can be ruined by a carbon track running along it. These things are common enough if a bug lands on a spacer. It's not a big deal.
  3. alfacliff
    Dec 13, 2013
    2,449
    428
    hot glue works also. just use the hot glue gun to make a blob to replace the broken insulator.
  4. tom_s
    Member
    Jun 27, 2014
    287
    342
    got a broken toaster lying around? the wafer that holds the element would be a good insulator, designed for heat.
    edit: drill required holes in it to depth you need and easy to cut with scissors.
