Ok, got rid of the breadboard and built on a piece of cardboard instead using the original circuit diagram from the original post except that I replaced the R3 1K resistor with a 180Ω since I do not have a high impedance earphone (text on the root page said to do this for regular headphones or a small speaker).
The result is, I can hear stuff! A good start. I have 2 problems though. First is that it sounds like I can only get 1 station with any kind of clarity enough to actually tell I'm hearing something. The second problem is that the darn thing just isn't loud enough. I mean, it's just a test circuit so I'm not expecting to fill the room with sound, but I have to put the speaker against my ear to hear it, and even still it's very hard to make it out. That in turn makes it difficult to tell what kind of station I'm getting and if I'm getting more than one.
I have a couple NTE48 general purpose amp NPN Darlington transistors that I picked up for that "totally bogus" 1W audio amplifier circuit. I wonder if someone can help me use one of those to boost the audio a bit so I don't have to make a trip to the parts store? The NTE48 Datasheet doesn't provide any example circuits like some do so I'm really not sure how to use it.
I thank all of you who have helped me to this point. It's clear the breadboard was the problem up to this point, now that I'm not using it, I can see progress and that's exciting so thanks again. Here are pics of the new build on the cardboard.
