Help with final project
Discussion in 'Homework Help' started by Knightmare69, Nov 30, 2010.
  1. Knightmare69
    Mar 28, 2010
    5
    I need help with the project i am doing in class(teacher wont give any advice) We need to hook up a circuit that will monitor the temp. of water to bring to a certain level. We were told to use a LM35,741 Op amp,A anolog to digital converter 0804, SLN 74Ls buffer, Uln 2803, use pull up resistors then connect it to a PLC using a thumbwheel to input desired temp and display actual temp on a LCD display. Any and all help would be greatly appreciated.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    The teacher doesn't need to give advice. If you understand how the various components work, you should be able to put this together.
    Start with the analog end. Get the data sheet for an LM35. Look at the data sheet for your A to D converter, and see if you can see where and why that op amp might be useful. What might that ULN2803 be good for?
    What 74LSxx logic would make a buffer, and what would it buffer? Would you use a binary or BCD TWS?
    Try to do a block diagram to get the sense of how the parts interrelate, and then do a schematic. From the data sheets, you will be able to calculate resistor values.
    By the way, look very carefully at the data sheet for that 741. Hint: they do not work with single supplies.
  3. Knightmare69
    Mar 28, 2010
    5
    Well im just wondering if I should use a voltage divider?
  4. tyblu
    Member
    Nov 29, 2010
    199
    16
    Let's see your schematic so far.
  5. Knightmare69
    Mar 28, 2010
    5
    I got it now I am now hooking it into a adc 0804 then into a 74ls240 buffer.
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Where did that pesky 741 go? Why an 'LS240?
  7. Knightmare69
    Mar 28, 2010
    5
    I got the 741 to work had to use a +10 -10 voltage with 80k and a 20 k resistor to get my gain of 5. My new stage is hooking up the 0804 adc to a 74ls240 buffer. Then into a ULN 2803 we have to use pull up resistors I'm trying to figure out what resistance to use. This is going to be interfaced with a PLC which is 24v. I dont have a schematic to upload we were not givin one so I am in the stage of doing that.
  8. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    I suggest learning how to draw a schematic. You'll need it anyway for your project.
  9. Knightmare69
    Mar 28, 2010
    5
    Ya thanks I know how.
  10. retched
    Dec 5, 2009
    5,201
    313
    Care to show the schematic?
    After all, anyone searching for help will not "see" what the resulting fix was.
