hello everybody, i need some help on how to use fets
i need to design a driver for a bipolar stepper motor using fets, i'm using two h bridges of n-channel and p-channel fets and a l297 drive. i use it with 5v for the l297 and 12v for the motor. until now everything works fine, but the circuit is intended to work with 48v . thats where my problem starts, i'm using irf530 n-channel fets and irf9530 p-channel fets and in the data sheet says that the max vgs(gate-source V) is of +/-20v and if it surpases that the fet is destroyed. then.... my question is, how can i use it for those conditions without destroying the fet and aplying most at least 46V in the coils of the motor?
P.S.
i've already tried with zeners, they dont work
P.S.
