I am modifying a guitar multi-effects unit for external switching of presets. The external footswitch uses 2 spst momentary switches and a trs cable. The problem I am having is on the multi-effects side.
The footswitches send either tip and sleeve or ring and sleeve, meaning that sleeve is always sent.
When I detach the sleeve connection from either of the buttons in the multi-effects unit the other button works correctly and vise versa. I am wondering if i could use a relay on the sleeve connection. I have attached a diagram of what is going on any help would be much appreciated.
