Hi All
Need help with a circuit diagram back emf protection of a timer module, relay and 24v shut down solenoid. I am using 3 wire shut down solenoid. switching hold in winding from a on / off switch and switching power to a timer module to switch earth to a relay to feed the pull in winding for 2 seconds. however i think backemf from the pull in winding is damaging my timer module. what is the best way to solve this problem. Thanks for the help in advance
cheers Peter
cheers Peter
