Help with eletronic ballast
Discussion in 'The Projects Forum' started by denissoncs, Oct 17, 2012.
Thread Status:
Not open for further replies.
  1. denissoncs
    Nov 8, 2011
    13
    Hello guys,
    I'm working on a eletronic ballast. I'm using a push pull configuration, using ir 2110 as a driver.
    I created a square wave of 40khz and I need a INVERTED square wave, such that the two waves NEVER becomes HIGH at the same time.
    I've tried buffer, some circuits on the internet, but it didn't work.
    I request some suggestions, please :)
    Denisson
  2. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    Without a schematic, we can not tell you what is going wrong.
    Please post your schematic over here?
    Attachments and Images
    Bertus
  3. denissoncs
    Nov 8, 2011
    13
    I attached two files. One is the ballast of a fluorescent LAMP i'm trying to implement. I'm using a IR2110 to drive two MOSFETS.
    As far as I understood I need to create two square waves of 40khz (this value is not fixed) such that when wave Hin is HIGH the other Lin is LOW and vice-versa.
    I tried to add a delay I properly calculated to create Hin and Lin using an adaptation of this circuit.
    But it doesn't work at this frequency due to the slew rate of the operational amplifier. It worked properly until about 2khz.
    There's any operational amplifier that will work at this 40khz frequency? If so, how do I know that?
    In fact, when I used a function generator the circuit is driving the transistors. But I want to create my own wave.
    I'm using 555 to create the square wave 40khz.
    I accept tips about this or anything related to ballasts :)
  4. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I am afraid the circuit is violating the ToS, as un-isolated main powered circuits are not allowed over here.
    You can have a look here for information on CCFL Circuits
    Bertus
  5. denissoncs
    Nov 8, 2011
    13
    I've read a lot about eletronic ballast but I still don't fully understand it. Could anybody look at this circuit I've built and tell me what is wrong?
    When I turn it on, the Ir 2110 IS NOT DRIVING the Ho signal to the high side transistor.
    If I change VCC to 19.5V, It started to overheat the transistor and I turned it off.
    Please, any tips? :)
    Thanks,
    Denisson
  6. bertus
    Administrator
    Apr 5, 2008
    15,799
    2,386
    I am sorry, but we do not discuss non isolated mains powered circuits over here.
    Fom the ToS:
    6. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will result in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    Bertus
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Try adding a transformer to the circuit, and revisit it. May I suggest an inverter, powering florescent from batteries is always popular.
Thread Status:
