Hi guys, i doing a project now which needs to plot graph from the digital singal, ( My project = using solar panel to obtain voltage reading and trasmitting the voltage reading data to analog-to-digital IC which will be connected to a wireless transmitter , then the receiver which will then receive digital signal , will be interface with rs232 , which will then be again converted into usb slot.... ) so my problem is should i use matlab or visual studio 2005 to read the usb digital data signal ? can some1 post some programming on how to read the usb drive and also how to plot a voltage reading data from the digital signal ? how to know the start and stop bit from the digital data.... Many thanks for the advice given thanks.... need urgent help.
