hey there, i have a pair of earphones i found somewere in my bunch of electronics things, i think they are from a nokia phone, they got a microphone and a button to answer calls, the problem is that when I listen to music on them, the voice doesnt sounds, when I do a left right test, both earphones sound when its supposed only one should sound.
I have tested it by applying an input signal to both chanels separately, and it works well, then i applied both signals with wires and it worked, but when i pug them to a computer or something they doesnt work.
i measured the resistance between the sleeve and the ring 1 and 2, and its 35 ohms, then i measured between ring 1 and ring 2 and its 70 ohms.
do you know what happens?
