Hello all,
I have the following project in mind:
2 phase Motor receives power
Motor pulls a line appr 2 feet at which point the line triggers a shut off switch
Motor is inactive until activated by the same on switch, but this time reverses polarity and releases the line for the same distance, triggers a second shut off switch and is again inactive
I am using a 2-phase 12V motor and a DPDT Relay (DYL 2S-D12) and 2 shut off switches.
the power is supplied via an IP 110V outlet to which a 20V transformer is plugged into.
Remotely, I will turn the IP outlet on to power the relay and will turn the power supply off after each function.
Explanation:
I have a trap door on a chicken coop which I wish to open in the morning and close in the evening remotely when not at home.
Any help would be appreciated!
Explanation:
