Help with door lock
Discussion in 'The Projects Forum' started by josh07, Sep 6, 2010.
  1. josh07
    Sep 6, 2010
    someone help me making a diagram for my project..
    we are goin to make a doorlock system...
    we are going to control it using pc and parallel port as connector
    we are going to use this things-
    mg solenoid
    SN74LS04 Hex Inverter
    5V 500ohm Reed Relay
    24V 10A SPDT Relay
    plss check if this diagram is correct..
  2. KMoffett
    Dec 19, 2007
    2,584
    234
    You forgot the diagram.
    Ken
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Welcome to the forums.
    Always start your own thread instead of posting onto the end of another - http://forum.allaboutcircuits.com/showthread.php?t=21341
    Are you committed to the use of the parallel port for the control? The old printer port has lost support and is generally not present in modern computers.
    Do you have a power supply for the relay? How did you come by the list of hardware?
