help with DM74LS190N
Discussion in 'The Projects Forum' started by Abin, May 31, 2012.
  1. Abin
    May 31, 2012
    5
    I'm trying to buld a circuit that wuld count objects on a conveyor belt. the ICs are-DM74LS190(counter), 7447 and 555. i havent had a problem with 7447 and the display but the 555 trigger circuit and counter are a noose around my neck.:( i try to preset the counter by grounding load and the parallel data inputs but nothing happens. the output just remains in 1110(- this is impossible right? because 74190 is a decade counter) and the latch input 4 is grounded only. i need urgent help as i need to finish my project in 3 days:rolleyes: pls help!! ty!1
  2. Abin
    May 31, 2012
    5
    and clocking pulses dont make any difference either wen 5 is high or low:eek:
  3. absf
    Dec 29, 2010
    1,493
    374
    Is enable "E" pin 4 grounded?
    Allen
  4. Abin
    May 31, 2012
    5
    yes 4 is grounded and i have also tried connecting it to Vcc. but no change. how can the o/p be 1110? in decade counter 1001 is the max possible right:confused:? pls help:)
  5. absf
    Dec 29, 2010
    1,493
    374
    If you want to count down from 9-0, the input has to be set as 1001 like this....
  6. Abin
    May 31, 2012
    5
    i havent used the 10k resistor pulled up from PL. and i have grounded pin5. other than that, everything is the same sir. but not working:confused:. pls help!!!
