Help with digital clock on multisim 10
Discussion in 'The Projects Forum' started by gillbensh, May 2, 2010.
  1. gillbensh
    May 1, 2010
    hello all!
    i need to do a little project on multisim that combine those components:
    74LS48D and 74LS160D and some resistors.
    well, i have started my project but i reach a point that i dont know what to do. im attaching my file so you can see what i did until now.
    i need to build second, minutes and hours clock with 7-sigment.
    as you see in my file i did only the seconds, its only count until 9 sec.
    how to make it count to 60 sec?????
    and how to make the minutes and hours properly?
    thank you very much!!
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    One 'LS160 can only count from 0 - 9. Add another and you can count 0 - 99.
  3. gillbensh
    May 1, 2010
    ok i know that, but how you make him count until 60 sec? after that 1 min should be appeared on the next 7-segment screen.
  4. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A few external gates can give an output at the count of 60 and even reset the counters to 1 at the next clock pulse by using the parallel load function. The same pulse can combine with the clock to count the next section (seconds -> minutes, or minutes -> hours).
    gillbensh likes this.
