help with diff amp - pwm input, dc output
Discussion in 'The Projects Forum' started by Ripper612, Aug 12, 2010.
  1. Ripper612
    Aug 3, 2010
    5
    Im trying to build a basic current sensor with a diffamp.
    My probleme is the signal is PWM through my shunt resistor. About 22V peak. What must i do with my diffamp to have an continous output signal between say 0 - 5 V?
    Thanks in advance
  2. Norfindel
    Mar 6, 2008
    235
    9
    What about using a low-pass filter to obtain a continuous signal from the PWM?
  3. Ripper612
    Aug 3, 2010
    5
    Thanks for the reply. I got it to work eventually. Low pass filter did the job.
    Just for curiosity...is there any other ways to measure the current?
  4. sage.radachowsky
    Member
    May 11, 2010
    241
    38
