Help with Dc charger for Laptop
Discussion in 'The Projects Forum' started by chino00007, Nov 16, 2011.
  1. chino00007
    Nov 16, 2011
    19
    I want to make a DC power supply for a HP computer model 6715b, that has 19.5V and 4.7 Amp. 90Watts
    Do anyone have a good schematic of the circuit that can help me!
  2. laixix
    Nov 16, 2011
    well , I wanted to do that one but I dont if i I can to do in diode or diode bridge !!!!
  3. bountyhunter
    Sep 7, 2009
    2,498
    507
    >90 watts is beyond what is considered practical for a liner supply. Most laptop cubes have a switcher in them. This is not a trivial design.
    chino00007 likes this.
  4. chino00007
    Nov 16, 2011
    19
    Yes, I know is not a trival design, is not something you will find in a high school I guess, but I want to know at least what is the typical thing that is damage at least in a Laptop charger because i don't really understand and maybe i can fix it :rolleyes:,at 100%,
    I know the logic, but not the complete understand, Can you help me bountyhunter with a simple design at least?
    or if not, could I make it with a simple power supply... that only gives me 19.5V and 20 amp???? I don´t know, it´s not about money, it´s about I want to make it,thanks anyway!!!
    Greetings!
  5. Wendy
    Mar 24, 2008
    20,766
    2,536
    You could make one, but there are plenty of generics on the market. I've tried to design several (actually one), there are several pitfalls to complicate matters, such as the IR drop in the wire.
  6. praondevou
    Jul 9, 2011
    2,936
    488
    Just to give you an idea of what a laptop adapter power supply could look like. Sure you want to build one from scratch?
    However, if you only want to fix them, I guess most often you will find blown/old capacitors, blown main switching ICs/transistors, semiconductors in general.
    If you want to repair them on a regular basis a variable/isolation transformer and an oscilloscope will be very helpful.
    http://www.tehnomagazin.com/Power-supply/Laptop-Power-supply-Adaptor-circuit.htm
    http://media.digikey.com/photos/rdl/evl6566a_75wadp_schematic.jpg
    http://www.datasheetdir.com/Ncp4302...y-Synchronous-Rectification+Application-Notes
    http://www.simplecircuitdiagram.com/2009/12/24/52w-smps-ac-dc-adapter/
  7. bountyhunter
    Sep 7, 2009
    2,498
    507
    The design they use is probably an offline switcher, not repairable.
    If it's a linear designe, it would be as heavy as a boat anchor and the size of a bowling ball.
  8. EarlAnderson
    Member
    Nov 13, 2011
    166
    hmmm... 90 watts for a charger is not a very efficient design. i would suggest using a switching power supply, in which you can find schematics of online, and then you could come up with something similar to that to meet your specs.
    i would actually recomend you BUY a charger
  9. t06afre
    May 11, 2009
    5,939
    1,222
    I doubt it is a easy way to build a charger that will charge your battery. The reason is that now a days. The charger is communication with the PC. If your PC sense that a non standard charger is connected. It will simply not charge the PC battery. So you have to get a charger that your PC may accept as a genuine HP charger. Also building a charger would cost much more than getting a second hand charger. You can not in this case just through some parts together and do some magic. In order to replace your lost or not working charger
  10. R!f@@
    Apr 2, 2009
    8,754
    760
    Definitely not a beginner project.
    You'll save a bunch if you buy one on Ebay
  11. chino00007
    Nov 16, 2011
    19
    OK. thanks for all the information anyway. :D
