Help with current required
Discussion in 'The Projects Forum' started by James4553, Aug 29, 2009.
  1. James4553
    Thread Starter Active Member
    Jun 7, 2008
    35
  2. mik3
    Feb 4, 2008
    4,846
    63
    You mean to connect them in parallel and not in series.
    If you consider the current drawn by these two chips a power supply with 20mA capability is more than enough. If you will power other devices with the same power supply you have to consider their current requirement.
  3. James4553
    Jun 7, 2008
    35
    Sorry, I meant I am connecting the two IC's together in series, but yes the power source will be powering them in parallel.
    I don't think I can get a 12V / 20mA plug pack, can I get a plug pack with a higher current and then make a current divider with resistors to get the right current?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    If you apply the proper voltage, the devices will only draw as much current as they need.
  5. James4553
    Jun 7, 2008
    35
    Great, thanks for the help!
  6. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Get a 12VDC wallwart, and then build an 8v supply, which is the recommended voltage for those ICs.
    You can test your circuit beforehand using 9v "transistor" batteries.
  7. KMoffett
    Dec 19, 2007
    2,584
    234
    I haven't heard of them referred to as "transistor batteries" for a long, long time. ;)
    Ken
