Help with connecting my timer switch to my geyser
Discussion in 'General Electronics Chat' started by ikettle, Jul 3, 2012.
  1. ikettle
    Jul 3, 2012
    Hi Guys, can anyone tell me how to connect this timer switch to my geyser.
    I have attached the photo of this timer switch. I know that from the geyser circuit breaker I must connect the live to L on the timer switch and then the neutral from the geyser circuit breaker to the N on the timer switch. I need to know what I need to connect to positions 1, 2 and 3?
    Any help will be appreciated.
  2. Sensacell
    Jun 19, 2012
    1,183
    276
    If only I knew what a "geyser" was? are we at Yellowstone?
    Context is everything.
  3. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
    I think you are talking about a boiler (a heated water resevoir).
    When the isolation is good enough you can use the timed powersupply.
    Bertus
  4. Dodgydave
    Jun 22, 2012
    5,152
    769
    Terminals 1,2,3 are a set of voltage free contacts so.
    Looks like terminals 1 &2, in series with the live of your geyser.check with a multimeter that terms 1&2 make contact when timer is active.
  5. mcgyvr
    Oct 15, 2009
    4,789
    975
    I'd think geyser is a waterfall or fountain pump???
    Do you not have the manual for the timer? Got a manufacturer/model number?
    Looks like those terminals are maybe for switches/contact closures to trigger the timer or override it or something..
  6. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
  7. dataman19
    Member
    Dec 26, 2009
    136
    29
    I'm hoping that he is talking about a geothermal phenominon - that would be cool...
  8. strantor
    Oct 3, 2010
    4,302
    1,989
    I command nature's geothermal forces, with this unassuming relay. If only I were Chuck Norris, I could ditch the relay.
    #12 likes this.
  9. ikettle
    Jul 3, 2012
    Actually a Geyser is a water boiler, used to heat water for domestic use, bathing, showering etc...It probably is a word from the Dutch as I am in South Africa.
    Terminals 1, 2 and 3 should go back to the geyser, which will allow the timer to control the current, allowing the geyser to switch on and off via the setting on the timer. I just dont know what I should connect to 1, 2 and 3.
  10. strantor
    Oct 3, 2010
    4,302
    1,989
    L & N need constant power. this is what keeps the timer powered and timing.
    #2 is the common terminal, #1 is normally open and #3 is normally closed.
    You would probably want to do the following:
    wire your hot wire to L and terminal 2.
    Wire your neutral wire to N and to the geyser.
    Wire terminal 1 to geyser (it will replace the currently installed hot wire)
  11. n1ist
    Mar 8, 2009
    171
    16
    Double check that the relay contacts can handle the current draw of the geyser.
    /mike
  12. Bernard
    Aug 7, 2008
    4,240
    414
    From tankless water heater-- 18 kW --Wow !!
