Hello all. I'm new here and am looking for some assistance with designing a circuit for my new car. The car has DRL (daytime running lamps) that double function as the 'brights'. During daytime use when headlights are not on, the DRL circuit gets around 2vdc. When the headlights are on, this circuit goes to 0vdc. Whenever the brights are activated this circuit goes to 12vdc.
I am adding LED's to the front of the car to also function as DRL's and am not yet decided upon two different scenarios so I will post both to get some input. The factory DRL circuit will be the trigger as to what the intended functionality is of my new LED DRL's. I will likely stick with scenario 1 as I am hesitant to cut the wire feeding the factory DRL lights since the car is a lease. The total draw of the new LED DRL's is 2amps @12vdc.
SCENARIO 1)
OFF-Whenever the DRL circuit is at 0vdc and the ignition circuit is at 0vdc, the LED DRL circuit should also be at 0vdc.
ON-Whenever the DRL circuit is at 2vdc and the ignition circuit is at 12vdc, the LED DRL circuit should be at 12vdc. This is for daytime use.
DIM- Whenever the DRL circuit is at 0vdc and the ignition circuit is at 12vdc, the LED DRL circuit should be at 2vdc (future adjustable to 12vdc if possible with potentiometer or other method). This is for night time use.
BRIGHT- Only when the brights are manually flashed, the DRL circuit will be at 12vdc and the ignition circuit is at 12vdc, the LED DRL circuit should be at whatever is easiest. This is not a common occurrence.
SCENARIO 2)
OFF-Whenever the DRL circuit is at 0vdc and the ignition circuit is at 0vdc, the LED DRL circuit should also be at 0vdc. (SAME AS SCENARIO 1)
ON-Whenever the DRL circuit is at 2vdc and the ignition circuit is at 12vdc, the LED DRL circuit should be at 12vdc and the factory DRL bulbs should be off (via a relay). This is for daytime use.
DIM- Whenever the DRL circuit is at 0vdc and the ignition circuit is at 12vdc, the LED DRL circuit should be at 2vdc (adjustable to 12vdc if possible with potentiometer or other method). This is for night time use.
My personal experience is that I am extremely comfortable soldering and troubleshooting with a multi-meter but I have not designed a circuit from scratch. I am also not familiar with the different brands and nuances of certain electronic components but if given part numbers and a block diagram I can easily assemble it and test accordingly. A few years back I worked in a car stereo/alarm shop and my day to day tasks were installing elaborate stereo systems, alarms, remote starters, keyless entries and cruise controls (yes, cruise controls!). I am familiar with the necessity of properly fusing circuits, running wires safely in the engine compartment in spilt loom, and relays. Lots and lots of experience with typical 12vdc relays. I have spent the last 16 years in the home and commercial automation industry so I am also familiar with I/O's, RS232, IR, and control logic.
Thank you in advance for your assistance!
SCENARIO 1)
SCENARIO 2)
