its Q907, says right on the front D2395. looked up datasheet. it tests bad. will TIP31a work as substitute?Do not confuse rectifier with transistor on the TO-220 package
Looks like it left a little scar on the board, blow out the back instead of the front?
yep, left side of jumper is on 10v per division 10uS. right side is .2v/div 10uS.Did you...
1. Cut that jumper?
2. Remove C908 and C925?
3. Replace Q905 and Q911?
4. Tested the signal at the right side of the cut jumper?
q907 is the last transistor on the + output of the dc/dc converter. its emitter should have +15v. tested badI'm still waiting to hear back on my last tests. I have lost track of where you are now.
You are confusing me here.yep, left side of jumper is on 10v per division 10uS. right side is .2v/div 10uS.
With the jumper cut, Q907, C908 and C925 all removed, what is the DC voltage reading (using DVM) on the RIGHT side of the jumper and the scope picture (no need to post photo, just describe it and height)?
It probably needed replacing anyway.i forgot to turn off power after several minutes c927 exploded.
Are you able to get at the right-hand side of R918 with the probe - the side connected to the transformer and two hexfets?
Or do you need me to post a picture of the solder side?
I am expecting to see 12V high pulses with 35kHz frequency.
Cool! Best news I've heard all week long.12.8v 36.7khz
by Duane Benson
by Duane Benson
by Jake Hertz
