help with capacitor size
Discussion in 'The Projects Forum' started by fancycoconut, Dec 1, 2014.
  1. fancycoconut
    Nov 4, 2014
    8
    I am converting my 24v AC supply to 24v DC to power the pump for my espresso machine.
    I am using this BR http://www.diyfancylights.com/files/specs/KBPC50005-KBPC5010.pdf
    I know I need to add a capacitor (relatively large at that) to smooth the output, but what values should I be looking at. My pump motor is 24v, max 36w, controlled by mosfet.
    Ethan
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    36W/24V = 1.5A
    C(ΔV) = q = it or C=it/(ΔV)
    Lets say your motor will tolerate 3V of ripple, so ΔV=3
    Assuming you are in a 60Hz country (we would know if you registered for the forum properly), t =8.3ms
    C = 1.5*0.0083/3 = 0.0042Farads = 4200uF
  3. wmodavis
    Oct 23, 2010
    737
    150
    How much ripple is acceptable in your application? You have essentially defined the current the motor requires but 'how smooth the output" you have not stated. Both are necessary to calculate the required filter capacitance.
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    If you rectify a 24VAC transformer you will end up with more that 24VDC. What you need is a 18VAC transformer.
  5. MikeML
    Oct 2, 2009
    5,451
    1,066
    One trade off is to use only a single half-wave rectifier, and that will drop the voltage somewhat...
  6. wmodavis
    Oct 23, 2010
    737
    150
    But it will also require a larger capacitor to achieve a specified amount of ripple.
  7. fancycoconut
    Nov 4, 2014
    8
    Dang, I already ordered my rectifier...
    I also ordered a 50v max 15000uF capacitor
  8. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    It is very doubtful you will need a cap, there are many DC controllers in use that use a SCR bridge to control a motor, in your case it will be a rectifier bridge as you do not need control, the only symptom of a unfiltered bridge is a 100/120Hz buzz when the speed is dropped, which does not apply in your case.
    So I would say, go ahead and just use the 24v AC supply and bridge, forget the cap.
    Edit: I see you are using a Mosfet, is this for variable speed?
    If so the higher filtered voltage is no problem as the recommended supply for a DC CONTROLLED motor is at least 10% above the motor rated voltage.
    http://electronicdesign.com/electromechanical/power-supply-considerations-servo-amplifiers
    Max.
  9. fancycoconut
    Nov 4, 2014
    8
    Yep, the mosfet is for speed control. So you are saying that if I use a full bridge rectifier on my 24V AC source to convert it to 24DC all I need is the FBR? Nothing else? I know some people were saying that this will give me over 24DC
  10. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    No. Only if it is an uncontrolled setup condition, if you are using a speed control mosfet circuit you can control the maximum speed, which is a result of overvoltage when using the cap. You just need to set the limit in some manner depending on the manner of control.
    How is your Mosfet circuit setup? Can you post the schematic?
    Max.
