Help with Capacitor Selection
Discussion in 'The Projects Forum' started by newtonium, Mar 2, 2011.
  1. newtonium
    Jun 5, 2010
    My Samsung Monitor (320P) is flashing about 100 times during power up. I have isolated the problem to 3 bad Capacitors in the main power supply just by their appearance (Domed Tops). This is a typical problem facing Samsung Monitors.
    The Capacitor Values are:
    1000uf/35v/105 deg.C/Radial/Through Hole/12mm(D) x 23mm(L)
    2200uf/35v/105 deg.C/Radial/Through Hole/16mm(D) x 30mm(L)
    The unknown Values are Tolerance and ESR. Would 10% be okay, or should I look for a lower Tolerance? I have no idea what would be a good ESR Value.
    Any suggestions would be helpfull
    Thanks.
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    10% should be fine. Make sure to get 105°C specified caps, and at least the specified voltage. Don't worry too much about ESR.
    newtonium likes this.
  3. newtonium
    Jun 5, 2010
    ESR- milliOhms or MegaOhms.
  4. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    MilliOhms.
    You'll likely see specs in the ~20m Ohm to 80m Ohm range. Lower is better; less heat build-up.
  5. newtonium
    Jun 5, 2010
    Excellent. Now I can pick what I need from thousands.
