Help with Capacitive Reactance "critical thinking"
Discussion in 'Homework Help' started by jestergixxer, Oct 12, 2012.
  1. jestergixxer
    Oct 12, 2012
    I have no idea on where to start with this problem. Can anyone point me in the right direction?, I have attempted to tackle it but came up short.
    you don't have to answer it but if you like too by all means take a crack at it, but all im asking is tell me where to start, i can do the rest of the problems
    Calculate: Xct, Xc1, Xc2, C1, C3, Vc1, Vc2, Vc3, Ic2 and Ic3. Your time and help is greatly appreciated.
    *Note that total voltage is 50v and not 25v
  2. justtrying
    Mar 9, 2011
    329
    396
    What were the steps that you have undertaken?
  3. pwdixon
    Member
    Oct 11, 2012
    488
    56
    You should know the formula for reactance of a capacitor so you can calculate the reactance of C2. Treat all the reactances just like a resistor network so that you can calculate the reactance of C1 knowing the supply voltage and current. Once you know the reactance of C1 you can work out the voltage at the junction. Knowing all the reactances you can the calculate all of the capacitor values from the formula for reactance of a capacitor. Job done.
    jestergixxer likes this.
  4. JoeJester
    Apr 26, 2005
    3,400
    1,218
    Start with the totals ...
    I set the results table in excel, so I could apply KVL and KCL to fill in as much as possible before starting the calculations. Here's where I started:
