Hi guys, I would like to try to build this 555 metal detector circuit for fun.
Would it be possible to replace the 10mH choke with a DIY air core?
I used an air coil calculator to figure out how to get 10mH and it seems
this might work according to the calculator:
Diameter: 5cm
Turns: 10
Length: 0.2cm
this results in a perfect 10.0 microhenries, would this air coil work?
Thanks for your help.
Diameter: 5cm
Turns: 10
Length: 0.2cm
