Help with Boolean circuit design
Discussion in 'Homework Help' started by Estudent1005, Jan 5, 2011.
  1. Estudent1005
    Jan 5, 2011
    I'm stuck on this homework question and was hoping for some help:
    Design a Boolean circuit that compares whether two-bit unsigned numbers are equal.
    I was given the hint : Construct a truth table and use XOR, AND, and NOT gates.
    Any advice on this one?
  2. n1ist
    Mar 8, 2009
    171
    16
    Well, you have 4 inputs and one output. Start by drawing the truth table (what does it mean when two two-bit unsigned numbers are equal?) Then figure out the logic from that.
    /mike
  3. Estudent1005
    Jan 5, 2011
    I understand the input logic (i think)
    would the inputs to the truth table look similiar to this:
    X1 X2 Y1 Y2
    0 0 0 0
    0 1 0 1
    1 0 1 0
    1 1 1 1
    how do I begin to create the Boolean function? From there, I know how to calculate the output and how to build the circuit, just stuck on the formula part..
    Thanks again!
  4. Estudent1005
    Jan 5, 2011
    do I need to show 2 formulas that are equal?
    for example:
    x1 XOR x2 = y1 NOTy2 AND NOTy1 y2
    something like that?
    x1, x2, y1, y2 being my input variables
  5. Georacer
    Nov 25, 2009
    5,151
    1,266
    The XOR gate has the property of giving a 1 if its two inputs are different. Therefore, if you pass the 4 bits through 2 XORs, and see even one 1, your numbers are different. I don't think a truth table will be of much help here. Just use your logic to sort this out.
