Help With Boolean Algebra
Discussion in 'Homework Help' started by Lilik, Aug 14, 2016.
  1. Lilik
    Aug 14, 2016
    Can someone please give me a hand simplifying this Boolean Algebra question? Thank you.
  2. ci139
    Member
    Jul 11, 2016
    341
    39
    ((Jesus)) as how can there be a question with basic stuff - if this is your main discipline - consider learning something that you are interested in
    - the conveyor method would be opening all parenthesis and regrouping the operands keeping in mind that
    X(true+false) = X -- or simply -- true + false = true
    X(true AND false) = false -- or simply -- true·false = false --
    -- the *FALSE usually is expressed as next
    -- F(var.-s) = op.-s + 0* = op.-s + false* = op.-s
    -- e.g. it's* usually not expressed
    another way is to tile your X together from 16 - state truth-table/carnaugh-map as in http://www.allaboutcircuits.com/worksheets/karnaugh-mapping/
  3. ci139
    Member
    Jul 11, 2016
    341
    39
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    This appears to be homework, so you need to show your best attempt to tackle it (it doesn't have to be correct, but it gives us a starting point to help identify where your approach is going wrong).
    You might try expanding it into SOP (sum of products) form to get started.
