Help with begginer circuit
John Brkic
Joined Nov 20, 2014
5
I have created a dc-dc booster using the AS1326 which has been designed specifically for this purpose. The problem is that I want to put 4 of these circuits into one PCB and I need the output to be unified. For example:I will have 4 dual inputs (+, -). The input for one single IC (AS1326) will vary from 0.7 to 5V and the outpt will be a fixed 3.3V. The problem is that I dont know how to connect the 4 outputs and add their voltaged together into one output. Is conecting the ICs together an option? Should I use a component that will unify all the 4 outputs and add them together to fom an output of 13.2V? Thanks in advance and apologies if my question is a too begginer one. Pleasee see icon and datasheet attached.
Regards
John
ErnieM
Joined Apr 24, 2011
8,377
Hi John, welcome to the forums.
Are the input voltages all separate and independent and (most importainly) isolated from each other?
If so then stacking them up should work to add the voltages together.
If not, you're making one big short.
John Brkic
Joined Nov 20, 2014
5
Hi guys,
First of all thanks for your replies.
@ErnieM I forgot to mention the input setup. I have 4 TEGs and each TEG will be connected to each IC (AS1326). So yes the input voltages are independent and isolated from each other. The circuit I did (on Eagle) is exactly the same a shown on figure 19, at page 11 of the datasheet.
@BobTPH I would certenly wouldnt want to limit the current to that of the smallest source since it is very important to get as much power as possible from the output. I just need to have 4 dual inputs and one output on one board.
BobTPH
Joined Jun 5, 2013
8,942
Combining dissimilar power sources to get the most out of them is not an easy task.
One way would be to boost each one to the same voltage, then parallel them, with some small resistors in series so that each contributes what it can.
Bob
John Brkic
Joined Nov 20, 2014
5
Hi @BobTPH ,
The ouput voltage will be fixed at 3.3V for all 4 outputs. The current will vary. Wouldnt the resistors drop the voltage? And by saying parallel them with resistors in series you mean somrthing like this?(see pic).
BobTPH
Joined Jun 5, 2013
8,942
No, connect one end of each resistor to each source, and the other end of all the resistors together to make the output.
The purpose of the resistors is to make up for small differences in the voltage of the sources. They should be small, designed to drop maybe 100mV at the expected current.
Oh, and the output voltage will be 3.3V since they are paralleled.
Bob
