Help with basics
Discussion in 'Homework Help' started by TsAmE, May 7, 2010.
  1. TsAmE
    Apr 19, 2010
    72
    I recently started doing electronics as a course at the beginning of this year and am still doubtful with a couple of things. For the attached picture, I am confused because:
    * I am not sure the way in which current flows through the circuit (although I know it + to -), but I mean does it just go from V to earth?
    * What difference does it make if you switch the resistors around for the respective circuits (hence what difference does this make to the earthed emitter and emitter-follower do?)
  2. PRS
    Aug 24, 2008
    989
    35
    You forgot to attach the circuit. ;)
  3. TsAmE
    Apr 19, 2010
    72
    Sigh I tried to but it said exception failed :(
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    In the FAQ is mentioned how to attach an image:
    Perhaps the file type may not be used.
    Bertus
  5. retched
    Dec 5, 2009
    5,201
    313
    If it says Exception Failed with a bunch of crazy garbage on the screen, press the backspace and click upload again.
    It happens with me all the time. I think the header gets cut short and it doesn't understand the filetype.
    I simply press backspace and click upload again and it works 99% of the time.
