Help with analyzing a DC circuit
Discussion in 'Homework Help' started by mapisto, May 16, 2011.
  1. mapisto
    Dec 25, 2009
    36
    I've got a circuit to analize and i'm not sure if i'm doing it right.
    First, I'm asked to write how many equations do i need for finding all the currents. my answer is 6 independent equations, because i've got 6 variables. is that right?
    Second, I'm required to find those equations by using ohm's law and kirchoff's current and voltage law:
    well, i've got only one loop in which i can use the KVL, and then 2 nodes where i can use KCL, but then i'm not realy sure about something.
    I think I could build another 4 equations by using Ohm's law on the 2K,3K,4K,8K resistors, but i'm not sure about the voltage. it made me a little confused, i don't know if I can just say that the voltage on each one is the voltage given near it. And if I can, why?!
    For example, is the voltage upon the 2k resistor 50v ?
    I know this is long, but I wanted to write to you what i'm thinking and to know if it's right.
    Please help,
    thanks!
      File size:
      42.8 KB
      28
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
      File size:
      26.5 KB
      17
    mapisto likes this.
  3. mapisto
    Dec 25, 2009
    36
    Thank you for your help, but my tutor won't let us use anything we haven't learnt yet...
    So i must use KVL, KCL and Ohm's law only.
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
      File size:
      38.9 KB
      19
    mapisto likes this.
  5. mapisto
    Dec 25, 2009
    36
    How can you make KVL on an open part of the circuit? there's only 1 loop there, and it's in the middle, or so i've thought : \ please explain.
    I'm reading the explanation in the link u've sent me, thank you.
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    No, there is no "open part" because we always can add this 100V and 60 V voltage sources to the diagram
      File size:
      28.2 KB
      12
    mapisto likes this.
  7. mapisto
    Dec 25, 2009
    36
    Ok, I guess I've got the picture all wrong, because my tutor always told us to use a -closed- loop for KVL.. so how exactly am i supposed to do KVL on the "open part" ? can i close the loop and it will stay the same? I feel i've got a huge hole in my understanding : \ please fill it up :|
    and btw, if i wanted to use Ohm's law on the 4kΩ resistor, could i just say that the voltage on it is 100v ? i have the feeling i'm being stupid o_O
    thank you for your patience!
  8. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, close the loop with the additional voltage source.
    And now you have four KVL loops.
    No, the voltage across 4kΩ resistor is not equal 100V.
    And we use capital "V" for Voltage
      File size:
      31.9 KB
      18
    mapisto likes this.
  9. mapisto
    Dec 25, 2009
    36
    Now i can see the point at last... Thank you!
    i've just read this explanation also:
    http://www.allaboutcircuits.com/vol_1/chpt_6/2.html
    but still, I'm not sure, so tell me if I'm wrong.
    The reason i'm allowed to consider this a close loop is because i'm taking the potential differences between the 2 spots?
    I understand what i need to do to solve the problem, but I won't be able to rest until I understand exactly why I'm allowed to do it. :rolleyes:
  10. Jony130
    Feb 17, 2009
    3,990
    1,115
    Yes, you have 100V potential differences between two points.
    And one of this points is common for the whole circuit.
    And we measure all the voltage respect to this common spot (reference point), also known as a "ground" (GND). And we assume that GND have zero voltage.
    mapisto likes this.
  11. mapisto
    Dec 25, 2009
    36
    I see,
    I think i've got it now.
    Thank you very much! you have no idea how grateful i am :)
