I'm trying to fix an old computer (MSX), but so far, no luck
On one msx, I have no video from video out or RF, I used multimeter, and compared with another MSX, it seems encoder on the no-video msx, shows reading of 4.58v on pin #30 while the working msx, shows varied number usually in the 2.xx v, I measured r g b pins both in and out, they give varied voltage same as the working MSX , same for cpu clock and the power voltage both are correct,
Does this shows that the encoder chip CXA1145 faulty? though RGB shows values and goes and comes from same chip. the video out comes directly from the chip's pin 20 to the encoder pin out #30.
Are there other possibilities beside the chip?
Encoder connection
Encoder details:
Encoder connection
Encoder details:
