Help with amps and volts
Discussion in 'Electronics Resources' started by rajbps01, Jan 28, 2015.
  1. rajbps01
    Jan 28, 2015
    9
    Hi Guys,
    Hope someone can help me. I have bought 2 cctv ptz camera. They use a 12v 1A output psu. Now i need to have this about 10 to 15 meters away. When I try to extend it the cams do not work. Can anyone help me please?
    Raj
  2. crutschow
    Mar 14, 2008
    13,474
    3,361
    Extend what?
    How do they not work?
  3. rajbps01
    Jan 28, 2015
    9
  4. MikeML
    Oct 2, 2009
    5,450
    1,066
    What gauge of wire did you use?
  5. rajbps01
    Jan 28, 2015
    9
    I been trying to use cat 5e so that I could use 1 cable only for data and power.
  6. rajbps01
    Jan 28, 2015
    9
    I used 2 pairs to bring data and have tried with either 1 or 2 pairs for power
  7. MikeML
    Oct 2, 2009
    5,450
    1,066
  8. rajbps01
    Jan 28, 2015
    9
    nope 1 per cable
    Have tried to double but still no joy :-(
  9. MikeML
    Oct 2, 2009
    5,450
    1,066
    Do the voltage loss calculation. I think you will see the problem....
    You could get a new 16V power supply;)
  10. rajbps01
    Jan 28, 2015
    9
    16v 1a?
  11. rajbps01
    Jan 28, 2015
    9
  12. MikeML
    Oct 2, 2009
    5,450
    1,066
  13. rajbps01
    Jan 28, 2015
    9
    ok used a normal 12v psu.
    If the normal cable is used, it works. If i connect the ethernet cable, then i have 12.6v but as soon as i connect the cam the readings keeps jumping but never over 1. its always .456 or 685 or so. Those last 2 figures were just examples, goes too quickly to read properly.
    Pls advise.
    this psu is a 2 amps
  14. MikeML
    Oct 2, 2009
    5,450
    1,066
    You might have the wires in the ethernet cable crossed. I would expect the voltage at the camera to be a steady, but low value, like 9V or 8V. There should be a +12V connection at both the power supply and camera, and a 0V (gnd) connection at both the power supply and camera.
  15. rajbps01
    Jan 28, 2015
    9
    Just double check and i been using the blue and blue/white and brown and brown/white for power.
    The other 4 cable, 2 pairs are working well as ethernet and can connect to it fine.
    So I am not sure anymore
  16. crutschow
    Mar 14, 2008
    13,474
    3,361
    Sounds like you may have the blue and brown cross wired.
    What does it do if you just use one pair of wires for the power?
