help with amplifier
Discussion in 'General Electronics Chat' started by volume, Sep 7, 2009.
  1. volume
    Sep 7, 2009
    hello friends
    i want to use a summing amplifier so i googled then i found this (MC1458)
    http://mediastudy.buffalo.edu/Robotics_Inventory/sheets/2172.pdf
    what i want to get from this amplifier is (0.5 and -0.5) as outputs with inputs of (logic 0 or logic 1) so how can i connect this amplifier ?
    then the outputs (0.5 or -0.5) will be an input to another amplifier with a gain of 38 ?how can i build the second amplifier?
    sorry if my questions seem stupid and that because of self study of the electronics
    thanks in advance
  2. PRS
    Aug 24, 2008
    989
    35
    What is the input voltage at logic 1 and what is the input voltage at logic 0? In fact, if you would explain what it is you want to do we might be able to offer a very simple (meaning good) solution.
  3. volume
    Sep 7, 2009
    in general what i want is that : logic 0 for forward movement (-19v)
    logic 1 reverse movement (+19v)
    so i get this idea by using the two amplifier
    in fact logic1 comes from a microcontroller if the voltage btween (2.5-3)
    and logic0 if the voltage (0-2.5)
    the output logic from the microcontroller will be an input for the first amplifier (summing amplifiier)
    i hope that i explain what you want to know
    waiting for the reply and if there is a different way to do what i want
  4. volume
    Sep 7, 2009
    by the way i think of the driver but it does not work :(
  5. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You may be passing over some steps. Good control of direction and speed with DC motors is with an H-bridge and pulse width modulation (PWM). There are dozens of topics on AAC dealing with them. Depending on your microprocessor, it could have the PWM interface already built in.
    Your last post -
    - is hard to interpret.
  6. aliensong
    May 13, 2009
    7
