Help with address lines
Discussion in 'General Electronics Chat' started by gammaman, Mar 3, 2009.
  1. gammaman
    Feb 14, 2009
    29
    How do I figure out the number of address lines?
    Say I have 2K x 16. How many address lines would this be?
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    That would be 2048 X 16. 11 lines.
  3. gammaman
    Feb 14, 2009
    29
    Thanks! Would you mind showing me how that is calculated?
  4. RiJoRI
    Aug 15, 2007
    536
    26
    1K needs 10 address lines (2^10 - 1024). Every time you double the "K" you add one address line.
    1K = 10 lines.
    2K = 11 lines.
    4K = 12 lines.
    1M = 1K*1K = 20 lines.
    Yeah, it can be done mathematically, but I find this method easier.
    --Rich
  5. mik3
    Feb 4, 2008
    4,846
    63
    2Kx19 means that you have a data bus 16 wide and 2000 memory locations and each memory location can store a 16bit value.
    Thus you need 2000 different addresses to access each memory location.
    In binary 2048=2^(11)
    Thus to achieve 2000 different addresses you need 11 lines.
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Logarithms to the base 2 is all there is to it.
  7. mik3
    Feb 4, 2008
    4,846
    63
    Yes, but it is not obvious for all people.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    I never claimed it was obvious.
  9. Ratch
    Mar 20, 2007
    1,068
    gammaman,
    2048 = 2^x ===> x = log10(2048)/log10(2) = ln(2048)/ln(2) = 11
    Use the log of any base you want and get the same answer.
    Ratch
  10. Papabravo
    Feb 24, 2006
    10,340
    1,850
    That's the ticket -- You 'da man!
