Hello everyone,
I am trying to get an auto-actuation circuit built with the use of a PIC, and two ADXL335 used for tilt information. The ADXL is 3 axis chip but I am using only one axis on each chip. The accelerometer reads 1.5V at 0degrees and goes to 1.2V at 90 degrees down and 1.8V at 90 degrees up. What i want to do is, have the chair to this base to auto actuate back to level when the base goes below 0 degrees. There's also a threshold angle that will cause a buzzer to go off indicating the base is tilted too much.
The actuator has its own controller and I am splicing into the actuator joystick which is a single pull with two throws. I was thinking of using a relay on each pull-throw connection and having the PIC output pin connected to the relay.
I have been reading a bit on ADC and the ADXL but want to double check if my code is correct before I connect anything. I know C but have never used PIC's so any help is appreciated. Heres what i have. Hopefully its good....I am mainly not sure if the whole top and initialization is correct (kinda just c&p from other example codes). I am using a 20Mhz external crystal. The ADXL uses 3V and so will the PIC if allowed which i believe it is.
Rich (BB code):
#include <stdlib.h> //standard include files
#include <pic.h>
#include <htc.h>
__CONFIG(DUNPROT & PWRTDIS & XT & WDTDIS & BORDIS & LVPDIS);
#ifndef _XTAL_FREQ
// Unless already defined assume 4MHz system frequency
// This definition is required to calibrate __delay_us() and __delay_ms()
#define _XTAL_FREQ 20000000
#endif
#define seatinput AN0 // variable seat will be used to reference AN0
#define chairinput AN1 // variable chair will be used to reference AN1
void InitLCD(void);
void DisplayC(unsigned char position, const char *str);
void DisplayCharacter(unsigned char pos, unsigned char c);
void Initial(void)
ADCON1 = 0x44; // Select PORTA pins for ADC or digital I/O
ADCS0 = 1; // Use A/D FOSC/8
TRISA = 0x0B; // Set I/O for PORTA
TRISB = 0x00; // Set I/O for PORTB
//chair angle
double ADConvert1(void)
double chairvolt=0;
CHS0 = 1; // Use channel AN1
CHS1 = 0;
ADON = 1; // Turn A/D on
__delay_us(20); // delay 30 usec to settle A/D acquisition
ADGO = 1; // Start conversion
while ( ADGO ); // wait for ADGO to go off signalling end of conversion
chairvolt = (ADRESH*4)+(ADRESL/64); //Caulating value of N
return chairvolt; // Display result
// seat angle
double ADConvert2(void)
double seatvolt=0;
CHS0 = 1; // Use channel AN2
CHS1 = 1;
seatvolt = (ADRESH*4)+(ADRESL/64); //Caulating value of N
return seatvolt; // Display result
int main(void)
Initial();
double chair = 0;
double seat = 0;
for (;;)
chair = ADConvert1();
seat = ADConvert2();
if(chair>1.5)
if(seat!=chair)
RB7=0; //no up
__delay_us(100);
RB6=1; //down to make even
if(chair<1.5)
if(seat<1.5)
RB6 = 0; //down = off
__delay_us(100);
RB7 = 1; //up = on
if(seat>1.5)
RB7 = 0; //up = off
__delay_us(100);
RB6 = 1; //down = on
if(chair<1.35)
RB5 = 1; // buzzer at threshold
if(chair>1.35)
RB5 = 0; //no buzzer
