Hello to all!
I'm building a home HEPA filtration unit and have a blower fan that produces more CFM that required, so I bought this: http://www.ebay.com/itm/161296624597?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
The transformer uses Banana Plugs. Since the unit is rated at 20 amps and will be using household current, I was hoping someone here could point me to somewhere I could purchase the properly rated banana plugs. I'm needing 3 sets of males and one female panel (with Pos and Neg) to mount on the outside of the fan box itself.
One set of males for the AC input and the other two for running from the Variac to the side of the cabinet which lead to the blower fan itself. I want to mount the plate on the outside of the cabinet which will be wired to the fan.
Any help would be greatly appreciated!
MK
MK
