Hello everyone, first post from a long time Lurker.
I have a project I have been working on where I'm using an ultrasonic signal to to stop a robot/buggy from hitting an obstacle. My circuit is designed so that when there is no signal, my relay is not activated and the motor circuit has current flowing to it, and when the circuit detects a signal the circuit amplifies the signal and then triggers the Relay.
As I have said I am having issues triggering the relay, specifically the relay as you would imagine is switching on and off as the signal is processed by the circuit. I ideally would like the relay to be active during the time the signal is being received. But currently I have no Idea how to go about this, for a period thought a 555 missing pulse counter might do the trick, but no (it sort of does but gives me the same issue I'm stuck with now). I also tried using a LM567 tone decoder, but alas Proteus doesn't have a model of it so I cant simulate it.
Here is what I have currently,
http://i.imgur.com/1ZapI.png
In this instance all there is is a 40kHz Square wave being generated, mainly because there isn't a transducer model in Proteus and I'm using a 555timer as an astable multivibrating ultrasonic generator. The circuit is inactive as I have the button switch open to simulate there being no obstacle.
http://i.imgur.com/koith.png
Here's is the circuit with the signal flowing through the circuit. The RC filter is designed for 40kHz, I then put it through the op-amp and filter it again. In the above pic I have the last opamp operating as a comparitor, but it switches on and off with the peaks and troughs of the signal, so in turn it switches the relay on and off.
Genuinely I am lost, I can see ways of doing it in my head but I can't move from conceptually in my brain to conceptually in a simulator. I'm pretty sure I can get the missing pulse generator to work if I can rectify the signal (in the above pic its the green signal) but for the life of me I'm lost on how to do it.
Can anyone help me, any type of help, where I am going wrong, what I could focus on, am I even using the right type of triggering circuit. Honestly anything would help I am at my whits end.
Here is my circuit with the missing pulse detector, if any of you are interested.
http://i.imgur.com/or8mv.png
Anyway thanks in advance, I think talking/typing through has helped a little allowed me to think at what I'm am trying to achieve (if that makes sense).
TheFrin
TheFrin
