Hello all. I am trying to build a very simple project to take a signal from a guitar (1/4 inch) and run it through a pot so that the volume could be adjusted and output the signal to an amp (1/4 inch). I am following a diagram which i found online.
Here is what i got. Input is on left, output is on right:
Now I get a little bit of very fuzzy sound only when i hold both inputs. But when i do this, the volume does not go up or down when i adjust the pot. ANy ideas on what I'm doing wrong? Thanks
