I am working on a custom computer case for my buddy as a surprise gift for when he returns home from Iraq. He is a big gamer and I have been building him a gaming computer over the last few months. I am almost finished with the case and now need a way to control the fans. Instead of buying an off the shelf and over priced rheobus I decided to build one that would fit my needs. The simple circuit for the voltage control using a lm317t, 300 ohm resistor, 240 ohm resistor and a 2.2k trim pot was easy.
What I am having a problem with is figuring out how to make an RGB led light up a different color at a supplied voltage. IE: red at 3 volts, blue at 7 volts and green at 12 volts. Can anyone help me with the circuit design? I am going to build this on perf board so no need to generate any pcb designs in eagle or anything. A simple schematic will suffice.
Thanks in advance.
Thanks in advance.
