Help with a semi persistent logic gate problem
Discussion in 'The Projects Forum' started by sniper98g, Aug 29, 2012.
  1. sniper98g
    Aug 29, 2012
    I have a project that I'm sure I can make a circuit for if I can just get my head wrapped around the logic. Unfortunately it has been over a decade since the last class I took in logic gates and I seam to have forgotten most of it.
    I need a gate system that will remain at a 0 output until it receives a 1 on both of two inputs. It will then remain at a 1 output as long as either of the two inputs still have a 1 input and then when both inputs are back to a 0 the output will drop back to 0.
    Any help with this would greatly appreciated.
  2. Papabravo
    Feb 24, 2006
    10,338
    1,850
    I don't think this is a combinatorial gate problem. It sounds like you need some memory to do the sequencing.
  3. absf
    Dec 29, 2010
    1,493
    374
    Is this what you're looking for?
    Allen
  4. Papabravo
    Feb 24, 2006
    10,338
    1,850
    That certainly is a non-combinatorial solution. You might want to mention that in this configuration the D and the Clock input should be tied high. It would not do for them to be beating up and down at high frequency, which they will if they are left open.
    absf likes this.
  5. kubeek
    Sep 20, 2005
    4,686
    805
    You need an S-R latch, two ANDs, one OR and one NOR. Sadly I dont have a suitable logic symbol for the latch, so I have to explain it in words.
    Inputs A,B go in a pair to one AND, to NOR and to OR gate.
    Output of AND goes to S input, output of NOR goes to R input of the latch.
    Output of the latch and output of the OR both go to the remaining AND where you take your output.
    Could anybody put that in a picture? :D
  6. absf
    Dec 29, 2010
    1,493
    374
    Is your S-R latch active high 4013 or active low 7474?
    Allen
  7. crutschow
    Mar 14, 2008
    13,472
    3,359
    You only need two chips for absf's solution. I think that's about as simple as you can get, other than using a micro.
  8. kubeek
    Sep 20, 2005
    4,686
    805
    I was thinking in positive logic, but your solution is much more elegant.
    absf likes this.
