I would like to measure temperatures from 0 to 450 oC and send the results to PC. I drawn this circuit after months of research. As I'm a real noob in electronic, would somebody take a look at my circuit to check if I have no error in it? Thank you.
I thought that I linearise the values in ATMEGA that I have, do you prefer using ADUC834 instead (as in your pdf link)?
as I said, I'm also not sure about whole system that I have, PT1000 interface, MAX232 to communicate with RS232, ATMEGA and it components (e.g. do I using the correct quartz there)
Do I need 1 Powerline for each of 3 PT1000s or it's enough to have one for all?
Using the ATMEGA for calculating the linearization is fine.
The PDF I showed you has some formulas in it that might help.
I am only worried about the current source.
The parameters for jfets can be quite off, so the currents may be different on the three channels you want to make.
This will result in different readings from the different channels.
