Help with a Project
Discussion in 'The Projects Forum' started by Snowy2008, Jul 15, 2011.
  1. Snowy2008
    Jul 15, 2011
    Hi can anyone help me with a project i just got given.
    Its got to do the following
    It has 2 12v supply ( one for the control circuit and 1 for the pumps)
    Its got to control 2 pumps to balance out a load (via pumping liquid into tanks to make the mounted item level)
    Have 3 lamps (2 to show what motor is running and 1 to indicate that the object is level)
    I know its got to do with Op Amp and maybe some relays can anyone help me out?
    Regards Dan
  2. wayneh
    Sep 9, 2010
    12,361
    3,220
    You'll need to supply much more info. How big are those pumps (voltage, current, horsepower, etc.)? How are you detecting "level" of your object? Lighting the lights will be easy. I assume LED indicators would be OK, like red for running and green for level, or something like that?
  3. Snowy2008
    Jul 15, 2011
    Soz not got much info on the pumps other than the 12v supply that runs them they are only small like fish tank pumps
    The level of my object is set with a potentiometer its a balance bar of such like a tightrope walkers pole for balance
    and yes LED's will be fine
