help with a precision oscillator
Discussion in 'Off-Topic' started by watertech, May 15, 2010.
Thread Status:
Not open for further replies.
  1. watertech
    May 8, 2010
    ok friends i need help whith building a square wave presicion oscillator,brainwaves,theta 3.5hz,6.3hz,alpha 7.83hz,7.0hz 10.0hz,betha 14.1hz,dave jhonnson sugest to use a LTC1799 IC and then a divider CD4020 I WANT TO USE A 6 position sw to switch from frecuencies,:confused::confused:any good help it is 4 my new chi generator:D:D:D thanks to all have a great one
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    How accurate do you want the frequencies to be?
    Can the 7.0 Hz be derived from the 14.1?
    This would give 7.05 Hz.
    And the 3.5 Hz?
    This would give 3.525 Hz.
    Bertus
    watertech likes this.
  3. t06afre
    May 11, 2009
    5,939
    1,222
    And what do you want to connect to this precession oscillator?
  4. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    Can't see how those frequencies would generate one.
  5. watertech
    May 8, 2010
    i like this pic i admire asian people
  6. watertech
    May 8, 2010
    as exact as possible,but i have no idea how to squematic,this frecuencies whith this 2 ics
  7. watertech
    May 8, 2010
    a chi generator,or more simple life force energy,im planing to do deep maditation,when listening this tones pasing this sounds thru mi orgonite chi generator,but not all people can design this multiple oscillator ,it need a good knoledge,of electronics it is a presicion square wave oscillator:confused::confused:
  8. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    The LT1799 uses a resistor to set the frequency.
    The accuracy is about 1.5 % (according to the feature list).
    I also attached the complete datasheet.
    Bertus
  9. retched
    Dec 5, 2009
    5,201
    313
    How can you be sure that one of the six you choose will help you. Every living thing responds slightly differently to different waves. If you use 3.3hz 3.9hz 4.1hz 5.8hz 6hz and 7.8hz as your 6 selections, but your brain and body just so happens to only respond to 3.45hz? You dont have that available on you 6 selector switch.
    Actually, you should use a pot, rather than a selector so you can achieve every frequency in between
  10. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
Thread Status:
