help with a motor circuit
Discussion in 'General Electronics Chat' started by westxjim, Dec 25, 2014.
  1. westxjim
    Dec 25, 2014
    I have a wood turning lathe with an AC induction motor. It has a reversing switch that I believe has gone bad. I am attaching the schematic from the control box that I can't figure our. help would be appreciated with the symbols. image.jpg
  2. MaxHeadRoom
    Jul 18, 2013
    10,860
    2,525
    It looks like one of the famous Chinese switches, the square box to the left of OUT is usually the way a coil is represented, the switch to the left of the coil is a manually operated switch or E-stop and the K is a manual operator for the relay, often on these machines the relay armature is pushed manually and then a retaining contact keeps it on.
    Many of these prints vary to some degree, there does not seem to be a standard unfortunately.
    If they have used wire numbers, you could trace them to confirm.
    Max
  3. westxjim
    Dec 25, 2014
    thanks!
