An AM signal with fM= 3 kHz, and carrier frequency fC= 120 kHz is to be detected by a linear envelope detector.How would we design the low-pass and high pass filter of the detector such that we get an undistorted waveform of the modulating signal from the output.
that is the question asked.
By a linear envelope detector (which is demodulating)we can remove the carrier-signal from the intelligence signal.
In the low pass filter, the capacitor would remove the high frequency. And diode in the filter will add distortion the signal.
