Help with a laser trip wire with a motor attached.
SiLK
Joined Oct 9, 2008
7
Objective:
To build a device that has an IR laser that when broken would activate a motor. The motor would be used to either pull the pin out of a Airsoft/Paintball grenade or strike it.
The Unit:
Would be attatched to a metal frame that would hold the grenade. The frame would be forced into the ground. The IR laser would simpally need to be broken and instantly activate the motor quickly.
Thank you for your help.
SiLK
scubasteve_911
Joined Dec 27, 2007
1,203
Your description is vague. How is the IR beam going to be broken?
If it is emitting from the box, then, it must be either reflected back to a sensor in the box or an external sensor must be used. I'm assuming you want it self-contained. If you're putting it on the ground, then you don't need a infrared laser.. You just just use infrared LEDs with a shrouded sensor to create a small field of view. You should modulate the signal so that light cannot false trigger.
Steve
SiLK
Joined Oct 9, 2008
7
Thank you for the reply.
The beam will be broken by feet hopefully. I only said IR because its in a very dimly lite building and I did not want anyone to see the beam. I would like it all self contained if at all possiable. I would mount it just off the floor.
scubasteve_911
Joined Dec 27, 2007
1,203
Okay, that makes more sense.
For the simplest circuit, I would use this detector
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=475-1080-ND
with this emitter
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=751-1208-ND
Hook them up like
http://home.cogeco.ca/~rpaisley4/PhotoDetectors.html
under Basic Infrared Detector
instead having the output of the opamp connected to (first circuit)
http://www.sampson-jeff.com/tcrobowar/motor1/ver1.htm
the mosfet should be a logic level or low-gate voltage type
These are your basic guidelines
Steve
